  • Dual Exhaust Picture Thread - Discussions
  • Talk about the most common LH mod, and why Chrysler didn't do it.
 #48647  by EasyRider300M
 September 12th, 2003, 2:14 am
where can you buy the y-pipe needed to make the staggered tips setup?
 #48649  by EasyRider300M
 September 12th, 2003, 2:50 am
isn't there a standard pre-made y pipe that is setup as nonstaggard and then you could mount the 2 tips to get the staggered look.
 #48650  by sdmike300m
 September 12th, 2003, 8:04 am
my guess is that those exist, but in my case they made both sets. There are a couple of variables that are car/tip specific, like the diameter of the Y-pipe, on both the inlet side and the tip ends, and the distance between the "Y" portions, which will be contingent on the diameter and shape of the tips that you use. Easy, go to any local high performance shop and ask who they recommend to do the exhaust. It's probably some hole-in-the-wall place that does incredible work rather than those Midas guys that hire and train kids to slap mufflers on as fast as possible.
 #48651  by sdmike300m
 September 12th, 2003, 8:06 am
99kelser - post pictures of how it turned out. Many people have asked about getting two sets of pipes back for true duals.
 #48652  by JCGold
 September 14th, 2003, 12:19 pm
EasyRider300M:Thank you for the compliment on the duals. I've been very pleased with the look. My apologies for not getting back to you sooner. Due to problems with the computer, I have not been able to use it for a week. As for the Y pipe, it appears that a standard Y was used and then modified. It looks like Russ cut the top of the Y to get the staggered look. These are the Magnaflow tips and all the work was done at Mesa Muffler (they provided everything). I would be happy to call Russ for more information if needed.
 #48654  by Humanx
 September 16th, 2003, 7:39 am
Mike, Those look great! I like the stagger.Try polishing the SS with Brasso. I found it works very well. ~Humanx 0]
 #48655  by sdmike300m
 September 16th, 2003, 3:07 pm
Thanks 0] , I'll try that
 #48656  by sdmike300m
 September 19th, 2003, 3:22 pm
2001M. If you reduce the size of that picture people could see the whole view of the rear at the same time. Try reducing the size to 640x480 max.
 #48657  by JCGold
 September 19th, 2003, 10:14 pm
sdmikeThe new tips look good! Now you won't have to cut your hand on them.
 #48659  by JCGold
 September 20th, 2003, 12:05 am
Mike,Yes, we all remember! :lol
 #48660  by Humanx
 September 22nd, 2003, 11:56 pm
2001M,Good looks!! Nice job !! Dern, those look (and probably sound) familiar! ~Humanx 0]
 #48661  by bigben300m
 December 4th, 2003, 6:18 pm
Hey guys, how is everyone? I am asking all that have had duals done, I want the following and what would be best:1. Less Cost2. Less Noise3. Good Sound and Performance4. I want to keep stock collectorWhat muffler would be best to use and tips? Where is the best place on the web to get them? I have looked at RAVIN mufflers, Magnaflow, Borla, and Dynomax. Which is the best with less noise? Last, I do want all stainless as they last longer right? Thanks in advance for all advice on this. Mike and Don, help! Lol.Ben.
  • 4
  • 5
  • 6
  • 7
  • 8
