  • how can i change the oil pressure switch???
 #261831  by jimgas
hello guys again!does anyone change the oil pressure switch?is easy to do it by myself???
 #261836  by Bill Putney
Screws out of the block or a fitting (depending on if you have the oil cooler or not) like any pipe fitting, of course after you pull the connector off (simple latch involved). It's supposed to require a special sensor socket to keep from damaging it by distorting the case, but I was successful doing it just carefully using pliers.
Highly recommended to use OEM part and not aftermarket - been *lots* of reports that aftermarket ones are not properly calibrated and you'll get more oil light flickering.
 #261862  by jimgas
im gonna buy an OEM cause i read that here again about the aftermarkets!!!so thank you so much!im gonna try change this weekend!!!
 #261885  by Bill Putney
You're welcome, Dimitris.
