  • Sub in rear deck
 #381968  by dcsally97
I am looking for details on doing this mod. What sub are you guys using with the Azera amp? How much cutting? Will the sub fit within the rear deck carpet in the trunk?
 #381970  by Sneke_Eyez
In my Special I have a 10'' Rockford in a Hyundai Tiberon sub box mounted in the passenger side rear trunk area. The Azera amp runs it well.
In the Intrepid, Bobby cut a hole for an 8'' Kicker in the back deck and the Azera amp runs that.
 #381981  by dcsally97
Are they dual voice coil subs? I have 4 wires going to one connector for the current broken Azera sub.
 #381982  by adu1982
Pacifica sub, sounds good to me, I'll measure the whole tonight. It is dual coil. I think it was an 09 Pacifica Limited
Sent from my moto g(6) using Tapatalk
dcsally97 liked this
 #381983  by dcsally97
adu1982 wrote: January 21st, 2020, 4:47 pm Pacifica sub, sounds good to me, I'll measure the whole tonight. It is dual coil. I think it was an 09 Pacifica Limited
Thanks Alex. What size is that sub?
 #381984  by dcsally97
Also wondering what impedance and power I should be looking for.
 #381996  by Sneke_Eyez
dcsally97 wrote: January 21st, 2020, 4:37 pm Are they dual voice coil subs? I have 4 wires going to one connector for the current broken Azera sub.
The one in the Special is - its this sub: https://www.amazon.com/gp/product/B005P ... UTF8&psc=1
The one in the Intrepid is not dual voice coil.
 #381998  by dcsally97
Thanks Ryan. I was actually looking at that one. How is the sound through the Azera amp?
 #382000  by adu1982
Sorry , I forgot to last night. I got lucky again and I'm going home early so I'll measure it.
 #382010  by Sneke_Eyez
I have been very happy with it.
 #382011  by dcsally97
It's on my list.
 #382019  by dcsally97
One last question. Which wires go where from the amp to the sub? The amp connector has 4 wires total.
 #382020  by adu1982
Well 2 for each coil. The harness I got from Keith, had white&black and white, and green and green&black. I wired black to the one with the black line.
 #382045  by adu1982
This sucks, they took the trash early today so the cut piece from the rear deck is gone. I measured from what I can see the sub itself is about 6-7 inches. The cover that came with it, is attached to the rear deck cover with screw from underneath so I can't pull it off. I'd have to take the back seat off and the cover off. But is roughly that....
 #382049  by dcsally97
Thanks guys. I have 2 more questions. What did you use to cut the deck? Ryan, do you have a cover for your sub, or just put the carpet back over it?
 #382051  by Sneke_Eyez
I have a cover out of a Lexus from the junkyard.
I believe we used a cutoff wheel on a grinder to cut it.
PunisherM, PunisherM liked this
 #382052  by dcsally97
That looks nice. Guess I have some shopping to do.
 #382054  by adu1982
HF cutoff wheels and saw. It will probably run you 20$ for a 10 pack blade pack and the saw itself if you find coupons or at least 20% separate ordersImageImage
I used about 5 of them so it was quick.i did take the little protective bracket thing of on mine, but it was for something else and I never put it back on. I wear glasses, but HF has cheap goggles too.
